Graph Bug
  • bobrivers
    • Feb 2007
    • 115
    Graph Bug
    Zabbix 1.3.4 (mysql 4.1.12)
    When adding items to a graph, if I select a color with letters in its definition (for instance: the default green is 009900. The red color is FF0000) it throws an error: Warning. Field [color] is not integer
    Changing it to "simple" colors (only numbers) works fine.
  • NOB
    • Mar 2007
    • 469
    it's the same here (1.3.4, PostgreSQL 8.1.3).
    The color is displayed fine in the selection "page"
    if colors like FF0000 are chosen.
    But the "Save" action does check for integers.
    If I use "0xFF0000" the integer check passes, but the color is unknown,
    later.
    Another problem using PostgreSQL:
    An error message appears during the display of the completed graph:
    * pg_query() [function.pg-query]: Query failed: ERROR: for SELECT DISTINCT, ORDER BY expressions must appear in select list[/usr/local/www/data/zabbix/include/db.inc.php:275]
    * Error in query [ select distinct g.name from hosts h, items i, graphs_items gi, graphs g where h.status=0 and h.hostid=i.hostid and g.graphid=2 and i.itemid=gi.itemid and gi.graphid=g.graphid and h.hostid not in (-1) and (g.graphid / 100000000000000)=0 order by h.host] [ERROR: for SELECT DISTINCT, ORDER BY expressions must appear in select list]
    * pg_fetch_array() expects parameter 1 to be resource, boolean given[/usr/local/www/data/zabbix/include/db.inc.php:394]
    [added]
    I'll try to fix it an dhope that the second report is an error triggered
    by the first one.
    Regards,
    Norbert.
    • NOB
      • Mar 2007
      • 469
      here is the patch:
      *** charts.php.orig     Tue Mar 27 11:34:18 2007
      --- charts.php  Fri Mar 30 08:24:33 2007
      *** 102,104 ****
      !               if(! ($row = DBfetch(DBselect(" select distinct g.name from hosts h, items i, graphs_items gi, graphs g ".
                                              " where h.status=".HOST_STATUS_MONITORED.
      --- 102,104 ----
      !               if(! ($row = DBfetch(DBselect(" select distinct g.name, h.host from hosts h, items i, graphs_items gi, graphs g ".
      It fixes this issue for me.
      The location of the file in the source is: frontend/php/charts.php
      if somebody wants to apply the fix in his installation.
      I guess Alexei knows where the file is :-)
      Regards,
      Norbert.
