Triggers problems (1.3.4)
  • eran
    • Apr 2007
    • 36
    Two problems with triggers:
    1. When creating a trigger with a dot in the expression the expression parsing breaks, which causes the SQL insert to fail. When parsing the expression should look for the last dot, not the first one.
      For example:
      {Newman_t: perf_counter[\ASP.NET Applications(__Total__)\Requests Total].avg(3)}>10
      The result is:
      Error in query [insert into functions (functionid,itemid,triggerid,function,parameter) values (11707,,12481,'NET Applications','__Total__')] [You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '12481,'NET Applications','__Total__')' at line 1]
    2. A minor problem - When using the insert button to insert a trigger expression for an item that contains a backslash, the backslash is removed when placed in the expression textbox. Any windows performance counter item is a good example of this.
    Eran
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Thanks for reporting this. Fixed!
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
