IP range in Autodiscovery.
  • kanour
    • May 2006
    • 105
    IP range type: 192.168.12.1-254 is not good idea.
    IP range type should be complete start and end ip: 192.168.12.1-192.168.12.254
    Reason is subneting networks.
    Jiri
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    I do not see a difference between 192.168.12.1-254 and 192.168.12.1-192.168.12.254. Am I the only one?
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • kanour
      • May 2006
      • 105
      So how would you do:
      172.18.2.1-172.18.5.254
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        172.18.2.1-255,172.18.3.1-255,172.18.4.1-255,172.18.5.1-254
        It is already supported.
        Alexei Vladishev
        My Twitter
        • kanour
          • May 2006
          • 105
          Ups, that is strange :-).
          It would be much easier to have full IPs, plus it would be much scalable and more correct.
          eg. OpenNMS:
          begin="172.17.1.1" end="172.17.1.254" (they also dont use shotcut)
          If you then have subnet: 172.19.11.1 - 172.19.120.254 (you will type long row).
          Also some subnets can go through 255 and then your notation would not be clear.
          But it is up to you. It was only suggestion.
          Jiri
          • Alexei
            Founder, CEO
            • Sep 2004
            • 5654
            Let's leave it is it is for now. I believe it is more error proof. Anyway the schema can be easily extended to support your schema as well.
            Alexei Vladishev
            My Twitter
