Login Bug
  • bobrivers
    • Feb 2007
    • 115
    Login Bug
    After that I upgraded to 1.3.5, I noticed that the login fucntion isn't working 100%.
    When doing a login, I fill the field "Login name" with "Admin" and then I press the "Enter" button. After that I'm redirected to the "Press here to disconnect/reconnect". The status bar shows that I'm "Connected as 'guest'". The menus are guest menus (without configuration and administration menus).
    If I click over a menu item, Monitoring for instance, the status bar changes, showing me that I'm connected as "Admin", and the menus are updated, showing the admin menus.
    This problem occured in two different machines (the only ones that I tested). Both are running Windows XP SP2. One is running with IE 6.0. The other with 7.0. I also tried to use it with Firefox 2.0.0.3. All with the same problem.
    I'm running zabbix in a Linux RHEL 4 box, running apache 2.0.52 (default RH packages) with php 4.3.9
  • dwoodruff
    • Mar 2007
    Login Bug
    I am having the same problem.
    If I enter the url to go directly to config.php, I get:
    ERROR: No permissions!
    Any ideas?
    Thanks,
    Donnie
    • dwoodruff
      • Mar 2007
      If I sign in with my Admin account and then go to the Monitoring tab, then the Configuration and Administration tabs show up and work.
      Not a fix, but a work around.
      Donnie
