1.3.6 SQL error, server dies [OpenBSD 4.1, PostgreSQL 8.2.3]?
  • schneck
    • May 2006
    • 62
    when starting the zabbix server, I get:
    268:20070503:174206 Starting zabbix_server. ZABBIX 1.3.6.
    268:20070503:174206 **** Enabled features ****
    268:20070503:174206 SNMP monitoring: YES
    268:20070503:174206 WEB monitoring: NO
    268:20070503:174206 Jabber notifications: NO
    268:20070503:174206 **************************
    268:20070503:174207 server #0 started [Watchdog]
    10460:20070503:174207 server #7 started [Trapper]
    17896:20070503:174207 server #8 started [Trapper]
    13600:20070503:174207 server #9 started [Trapper]
    26155:20070503:174207 server #10 started [Trapper]
    14470:20070503:174207 server #11 started [Trapper]
    15808:20070503:174207 server #12 started [ICMP pinger]
    29093:20070503:174207 server #13 started [Alerter]
    24151:20070503:174207 server #14 started [Housekeeper]
    18140:20070503:174207 server #15 started [Timer]
    14309:20070503:174207 server #17 started [Node watcher. Node ID:0]
    12034:20070503:174207 server #18 started [Discoverer]
    14669:20070503:174207 server #1 started [Poller. SNMP:ON]
    16791:20070503:174207 server #4 started [Poller. SNMP:ON]
    19166:20070503:174207 server #6 started [Poller. SNMP:ON]
    24151:20070503:174207 Executing housekeeper
    9529:20070503:174207 server #16 started [Poller for unreachable hosts. SNMP:ON]
    18731:20070503:174207 server #2 started [Poller. SNMP:ON]
    23634:20070503:174207 server #3 started [Poller. SNMP:ON]
    27740:20070503:174207 server #5 started [Poller. SNMP:ON]
    9529:20070503:174208 Query::select h.hostid,i.itemid from hosts h,items i where mod(h.hostid,1)=0 and i.nextcheck<=1178206928 and i.status in (0) and i.type not in (2,7,9) and h.status=0 and h.disable_until<=1178206928 and h.errors_from!=0 and h.hostid=i.hostid and i.key_ not in ('status','icmpping','icmppingsec','zabbix[log]') and h.hostid>=100000000000000*0 and h.hostid<=(100000000000000*0+99999999999999) group by h.hostid order by i.nextcheck
    9529:20070503:174208 Query failed:PGRES_FATAL_ERROR:ERROR: column "i.itemid" must appear in the GROUP BY clause or be used in an aggregate function
    268:20070503:174208 One child process died. Exiting ...
    268:20070503:174210 ZABBIX Server stopped
    I'm not that well versed in SQL, but I think GROUPing requires something like count($) or similar, doesn't it?
    \Bernhard.
    PS: 1.3.6 compile works well on OpenBSD-4.1 now.
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Thanks for reporting this!
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      The issue was fixed.
      Alexei Vladishev
      My Twitter
      • Markus
        • Jan 2006
        • 39
        Sorry Alexei, the problem is still there. Now the 'order by i.nextcheck' clause is causing the same problem:
        select h.hostid,min(i.itemid) from hosts h,items i where mod(h.hostid,1)=0 and i.nextcheck<=1178363670 and i.status in (0) and i.type not in (2,7,9) and h.status=0 and h.disable_until<=1178363670 and h.errors_from!=0 and h.hostid=i.hostid and i.key_ not in ('status','icmpping','icmppingsec','zabbix[log]') and h.hostid>=100000000000000*0 and h.hostid<=(100000000000000*0+99999999999999) group by h.hostid order by i.nextcheck
        5229:20070505:211430 Query failed:PGRES_FATAL_ERROR:ERROR: column "i.nextcheck" must appear in the GROUP BY clause or be used in an aggregate function
        Does the result have to be in sorted order?
        Markus
        • Alexei
          Founder, CEO
          • Sep 2004
          • 5654
          I would prefer to have it sorted, however it is not required. Remove 'oder by...' to make it work. Fixed again.
          Alexei Vladishev
          My Twitter
