Not found curl library
  • BusteR81
    • Apr 2007
    • 150
    1.3.6 --enable-statc still cause
    checking curl-config... /usr/local/bin/curl-config
    checking version libcurl ... 7.16.2
    checking main in -lcurl ... yes
    checking whether libcurl usable ... no
    configure: error Not found Curl library.
    On centOS 4.4 with Curl 7.16.2 installed. Anyone know WHAT are some examples names of Curl library files and WHERE should they be located? so that i can double confirm it is not err on my side.
    THnx
  • BusteR81
    • Apr 2007
    • 150
    solution for libcurl lib
    mine is CentOS 4.4
    installed libcurl4-7.16.2-1.i386.rpm
    installed libcurl4-devel-7.16.2-1.i386.rpm
    run ./configure WITHOUT --enable-static will be smooth installation of zabbix 1.3.6
