[1.3.7 r4114] Net-SNMP configuration broken again (without --enable-static)
  • Farzad FARID
    • Apr 2007
    • 79
    Hi, Net-SNMP configuration is broken again! This is on a 64 bits Fedora Core 5.
    If I try to configure an agent with the following line:
    ./configure --prefix=/opt/zabbix-agent --enable-agent --with-mysql --with-libcurl --with-net-snmp
    it breaks. The "config.log" says:
    configure:9027: checking for net-snmp-config
    configure:9045: found /usr/bin/net-snmp-config
    configure:9057: result: /usr/bin/net-snmp-config
    configure:9111: checking for main in -lnetsnmp
    configure:9140: gcc -o conftest -g -O2  -I/usr/include/rpm -I/usr/local/include -I/usr/include/gdbm -I/usr/lib64/perl5/5.8.8/x86_
    64-linux-thread-multi/CORE -I. -I/usr/include/net-snmp       conftest.c -lnetsnmp   -lresolv -lnsl   >&5
    /usr/lib/gcc/x86_64-redhat-linux/4.1.1/../../../../lib64/libnetsnmp.so: undefined reference to `EVP_DigestInit'
    /usr/lib/gcc/x86_64-redhat-linux/4.1.1/../../../../lib64/libnetsnmp.so: undefined reference to `EVP_DigestFinal'
    /usr/lib/gcc/x86_64-redhat-linux/4.1.1/../../../../lib64/libnetsnmp.so: undefined reference to `EVP_DigestFinal_ex'
    /usr/lib/gcc/x86_64-redhat-linux/4.1.1/../../../../lib64/libnetsnmp.so: undefined reference to `AES_set_encrypt_key'
    /usr/lib/gcc/x86_64-redhat-linux/4.1.1/../../../../lib64/libnetsnmp.so: undefined reference to `EVP_md5'
    /usr/lib/gcc/x86_64-redhat-linux/4.1.1/../../../../lib64/libnetsnmp.so: undefined reference to `HMAC'
    /usr/lib/gcc/x86_64-redhat-linux/4.1.1/../../../../lib64/libnetsnmp.so: undefined reference to `EVP_MD_CTX_cleanup'
    /usr/lib/gcc/x86_64-redhat-linux/4.1.1/../../../../lib64/libnetsnmp.so: undefined reference to `SSLeay'
    /usr/lib/gcc/x86_64-redhat-linux/4.1.1/../../../../lib64/libnetsnmp.so: undefined reference to `EVP_sha1'
    /usr/lib/gcc/x86_64-redhat-linux/4.1.1/../../../../lib64/libnetsnmp.so: undefined reference to `EVP_MD_CTX_init'
    /usr/lib/gcc/x86_64-redhat-linux/4.1.1/../../../../lib64/libnetsnmp.so: undefined reference to `EVP_DigestUpdate'
    /usr/lib/gcc/x86_64-redhat-linux/4.1.1/../../../../lib64/libnetsnmp.so: undefined reference to `RAND_bytes'
    /usr/lib/gcc/x86_64-redhat-linux/4.1.1/../../../../lib64/libnetsnmp.so: undefined reference to `DES_cbc_encrypt'
    /usr/lib/gcc/x86_64-redhat-linux/4.1.1/../../../../lib64/libnetsnmp.so: undefined reference to `DES_ncbc_encrypt'
    /usr/lib/gcc/x86_64-redhat-linux/4.1.1/../../../../lib64/libnetsnmp.so: undefined reference to `DES_key_sched'
    /usr/lib/gcc/x86_64-redhat-linux/4.1.1/../../../../lib64/libnetsnmp.so: undefined reference to `AES_cfb128_encrypt'
    But if I try to compile a server, always withtout "--enable-static", it works!
    configure:9140: gcc -o conftest -g -O2   -I/usr/include/mysql -g -pipe -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector --p
    aram=ssp-buffer-size=4 -m64 -mtune=generic -D_GNU_SOURCE -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -fno-strict-aliasing -fwrapv
        -I/usr/include/rpm -I/usr/local/include -I/usr/include/gdbm -I/usr/lib64/perl5/5.8.8/x86_64-linux-thread-multi/CORE -I. -I/us
    r/include/net-snmp      -L/usr/lib64/mysql -L/usr/lib64    -L/usr/kerberos/lib64     conftest.c -lnetsnmp   -lresolv -lnsl    -lm
    ysqlclient    -lcurl  >&5
    configure:9146: $? = 0
    configure:9164: result: yes
    If I add "--enable-static" to the agent configuration, it works too:
    64-linux-thread-multi/CORE -I. -I/usr/include/net-snmp   -static     conftest.c -lnetsnmp   -lresolv -lnsl   -lcrypto -lm -lwrap
    -lcrypto >&5
    And once again if I suppress the line "if test "x$enable_static" = "xyes"; then" in the configure scripts, configuration and compilation works again.
    Regards
  • richlv
    • Oct 2005
    • 3112
    a bit cleaner solution, imho :
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      It looks like a dependency problem of the Fedora Core 5 itself.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
