Out of memory - Discovery
  • bobrivers
    • Feb 2007
    • 115
    I'm trying to test zabbix 1.3.8. I configured a discovery rule to find devices (10.44.1.0-255) using TCP (port 23)
    Then I created an action with just one condition (discovery status = up) and three operations: add host, add to group and link to template (Template_SNMPv2_Device).
    Just after one discovered device (10.44.1.2) the zabbix_server died with out of memory...
    PHP Code:
      2475:20070518:115511 Query [select hostid from hosts_templates where templateid=10019]
    2475:20070518:115511 Added new item '10.44.1.2:sysName'
    2475:20070518:115511 Query [select distinct t.triggerid from triggers t, functions f, items i where i.hostid=10018 and f.itemid=i.itemid and f.triggerid=t.triggerid]
    2475:20070518:115511 Query [select description,priority,status,comments,url,expression from triggers where triggerid=12812]
    2475:20070518:115511 Query [select triggerid_up from trigger_depends where triggerid_down=12812]
    2475:20070518:115511 Query [select distinct t.triggerid,t.templateid from functions f,items i,triggers t  where t.templateid=0 and t.triggerid=f.triggerid and i.itemid=f.itemid and i.hostid=10019]
    2475:20070518:115511 In DBget_maxid(triggers,triggerid)
    2475:20070518:115511 Query [select nextid from ids where nodeid=0 and table_name='triggers' and field_name='triggerid']
    2475:20070518:115511 Query [update ids set nextid=nextid+1 where nodeid=0 and table_name='triggers' and field_name='triggerid']
    2475:20070518:115511 13019
      2475
    :20070518:115511 Query [insert into triggers (triggerid,description,priority,status,comments,url,value,expression,templateid) values (13019,'icmpInAddrMaskReps on {HOSTNAME} is too High',3,0,' ','',2,'{???:???}',12812)]
    2475:20070518:115511 Query [select itemid,function,parameter,functionid from functions  where triggerid=12812]
    2475:20070518:115511 out of memory. requested '-1079926342' bytes.
    2425:20070518:115511 One child process died. Exiting ...
    2428:20070518:115511 Got signal. Exiting ...
    2429:20070518:115511 Got signal. Exiting ...
    2431:20070518:115511 Got signal. Exiting ...
    2433:20070518:115511 Got signal. Exiting ...
    2434:20070518:115511 Got signal. Exiting ...
    2435:20070518:115511 Got signal. Exiting ...
    2458:20070518:115511 Got signal. Exiting ...
    2459:20070518:115511 Got signal. Exiting ...
    2463:20070518:115511 Got signal. Exiting ...
    2465:20070518:115511 Got signal. Exiting ...
    2468:20070518:115511 Got signal. Exiting ...
    2470:20070518:115511 Got signal. Exiting ...
    2472:20070518:115511 Got signal. Exiting ...
    2436:20070518:115511 Got signal. Exiting ...
    2442:20070518:115511 Got signal. Exiting ...
    2444:20070518:115511 Got signal. Exiting ...
    2446:20070518:115511 Got signal. Exiting ...
    2448:20070518:115511 Got signal. Exiting ...
    2450:20070518:115511 Got signal. Exiting ...
    2453:20070518:115511 Got signal. Exiting ...
    2455:20070518:115511 Got signal. Exiting ...
    2457:20070518:115511 Got signal. Exiting ...
    2425:20070518:115513 ZABBIX Server stopped
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    It took several hours time to reproduce this problem. It wasn't easy. The problem is fixed in the latest SVN code.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
