Reminder of some open bugs that need to be solved before final release
  • Farzad FARID
    • Apr 2007
    • 79
    As I see that the 1.4 release is coming soon, I'm making a list of some blocking or serious bugs I've found recently.
    First some configuration/compilation issues:
    I still have some issues on my test platforms:
    • The "status" item does not work on any of my 2 platforms
    • "icmpping" and "icmppingsec" work on one zabbix server but not on the other (both running 1.3.9). On one of my installation, these 2 items suddenly stopped returning values 10 days ago. Whatever I do I cannot get them to work again but I have not found any suspicious error or warning in the logs.
    Regards
  • Farzad FARID
    • Apr 2007
    • 79
    I solved the ping problem. Apparently the setuid bit of the "/usr/sbin/fping" program had disappeared.. So this is not a real issue, sorry.
    But, i still have a problem with "status", which seems to act erratically: one some hosts it is up, on some other it is down, on most servers it was not even calculated once.
    Regards
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      I'm pretty sure the "status" works fine with the latest code.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
      • Farzad FARID
        • Apr 2007
        • 79
        I'm running 1.4 r4178, and even hosts added today do not have any "status" value. Every host has at least "icmpping*" defined plus some custom items defined as external scripts.
        I don't know where to look or what specific debug message I must look at...
        Regards
        • dash
          • Mar 2007
          • 16
          Are we talking about trigger status here? I had same problem couple of month back, and I believe I even sent in a patch in private (not sure if it's the correct fix).
          Also after zabbix server restarts, the status seems to be out of whack. To solve this I have to go to each trigger and do a save, then the status seems to be ok.
          Another problem I had a long time back (someone just mentioned it again): Template graphs in a screen become invalid if you go back to the template graph and do a save.
          BTW, I haven't tried the later svn code yet.
          • dash
            • Mar 2007
            • 16
            While we're on the subject of changes before 1.4. I have couple of more requests:
            1) how do I backfill some missing samples into Zabbix? Say I missed bunch of item data and I want to save them into Zabbix, each item with old timestamp. How do I do this? This is needed so that Zabbix has a complete history of items. (Problem caused by network outage, etc).
            2) Import/export with proper template linkage. This will help manage a large installation if I have tons of hosts (linked to a template).
            • Farzad FARID
              • Apr 2007
              • 79
              I'm talking about the "status" item. I haven't defined any trigger on it yet as I can't get values
              Regards
