Perfomance problem: High CPU Usage
  • Filter
    I'm installed zabbix 1.3.8 on FreeBSD 5.5
    Server has 4 CPU and 3.5 GB of RAM + 4 GB of SWAP
    As resullt 6 zabbix_server process uses all avalable CPU resources.
    I'm add only 1 host with about 224 items.
    On another FreeBSD 6.2 server with 1 CPU and 200 MB of RAM all ok .
    Any ideas?
    PS:
    Sorry for English
    I hope, this bug solved.
    Try to use 1.4
      Try to use 1.4
      I see the same problem on 1.4, but with old configs (from 1.3.4)
      After config rewriting (from 1.4 distr), problem gone out...
        Hmm, interesting. Any hint on reproducing this?
        Alexei Vladishev
        New York | Tokyo | Riga
        My Twitter
          I'm monitoring swiches in LAN with SNMPv3 and md5 auth + des encryption
          "BIG" Server has 4 cpu, each at half slower than an "SMALL" (~4x1000Mhz).
          I think that all because of DES encryption. By default snmp using as i know triple DES in CBC mode, which as I know not very fast (AES Encryption not implemented in zabbix).
          Sory for that post, now I'm going to think that this is not a zabbix bug and server is realy too slow for that.
          Within the next few days I'll install v 1.4 and I'll disable encryption on some test swiches and test perfomance.
          It is interesting that top and ps shows that process sleping.
          BIG Server:
          last pid: 2021; load averages: 0.86, 0.86, 0.79 up 0+01:30:54 02:10:53
          128 processes: 2 running, 126 sleeping
          Mem: 101M Active, 37M Inact, 71M Wired, 652K Cache, 52M Buf, 3397M Free
          Swap: 4096M Total, 4096M Free
          PID USERNAME PRI NICE SIZE RES STATE C TIME WCPU CPU COMMAND
          1309 zabbix 8 5 4744K 3852K nanslp 1 5:30 13.18% 13.18% zabbix_server
          1308 zabbix 8 5 4744K 3852K nanslp 1 5:20 12.55% 12.55% zabbix_server
          1307 zabbix 8 5 4744K 3852K nanslp 2 5:20 12.06% 12.06% zabbix_server
          1306 zabbix 8 5 4744K 3852K nanslp 1 5:20 11.33% 11.33% zabbix_server
          1311 zabbix 8 5 4744K 3852K nanslp 3 5:21 10.84% 10.84% zabbix_server
          1310 zabbix 102 5 4764K 3856K CPU3 1 5:29 10.25% 10.25% zabbix_server
          583 mysql 20 0 67088K 40436K kserel 0 5:58 0.63% 0.63% mysqld
          245 root 96 0 3736K 2516K select 3 0:32 0.54% 0.54% ppp
          498 root 96 0 3364K 2772K select 3 0:18 0.05% 0.05% ssh
          684 root 86 -10 60164K 16296K select 1 1:01 0.00% 0.00% utm5_core
          571 root 96 0 1472K 692K select 2 0:37 0.00% 0.00% ndsad
          591 www 20 0 18772K 15304K lockf 3 0:11 0.00% 0.00% httpd
          587 www 20 0 18236K 14576K lockf 1 0:10 0.00% 0.00% httpd
          952 root 96 0 3444K 2412K select 0 0:09 0.00% 0.00% ppp
          921 root 8 0 6292K 4636K nanslp 3 0:08 0.00% 0.00% verlihub
          1018 www 20 0 19812K 16320K lockf 3 0:08 0.00% 0.00% httpd
          590 www 20 0 18772K 15116K lockf 1 0:07 0.00% 0.00% httpd
          SMALL Server
          last pid: 35842; load averages: 0.90, 0.60, 0.55 up 1+10:35:57 02:14:46
          84 processes: 2 running, 82 sleeping
          Mem: 112M Active, 12M Inact, 52M Wired, 11M Cache, 29M Buf, 576K Free
          Swap: 303M Total, 43M Used, 259M Free, 14% Inuse
          PID USERNAME THR PRI NICE SIZE RES STATE TIME WCPU COMMAND
          845 zabbix 1 8 5 4512K 1184K nanslp 90:13 5.91% zabbix_server
          843 zabbix 1 8 5 4512K 1392K nanslp 90:04 5.91% zabbix_server
          844 zabbix 1 8 5 4512K 1172K nanslp 90:56 5.57% zabbix_server
          846 zabbix 1 103 5 4528K 1408K RUN 89:58 5.42% zabbix_server
          847 zabbix 1 8 5 4512K 1392K nanslp 89:58 4.49% zabbix_server
          848 zabbix 1 8 5 4512K 1396K nanslp 89:57 4.35% zabbix_server
          35836 root 1 20 0 4500K 2368K pause 0:01 3.83% csh
          35833 root 1 96 0 6224K 2652K select 0:01 0.50% sshd
          750 mysql 27 20 0 61660K 19036K kserel 91:05 0.24% mysqld
          745 www 1 4 0 26220K 14696K accept 11:59 0.00% httpd
          746 www 1 4 0 23876K 12304K accept 11:40 0.00% httpd
          747 www 1 4 0 21620K 10168K accept 11:36 0.00% httpd
          744 www 1 4 0 24040K 12296K accept 11:20 0.00% httpd
          832 www 1 4 0 26204K 13952K accept 11:14 0.00% httpd
          748 www 1 4 0 25456K 12272K accept 10:46 0.00% httpd
          833 www 1 4 0 26060K 11928K accept 10:40 0.00% httpd
          31804 www 1 4 0 25748K 12284K accept 10:35 0.00% httpd
          32948 www 1 4 0 21756K 10844K accept 1:22 0.00% httpd
          PS
          As always Sorry for English
            Zabbix use net-snmp or ucd-snmp for communicate with snmp device and AES not emplement iin net-snmp
              If Zabbix use net-snmp library, it doesn't mean that Zabbix support all features that this library implement.
              Source 1.3.8:
              else if(item->snmpv3_securitylevel == ITEM_SNMPV3_SECURITYLEVEL_AUTHPRIV)
              session.securityLevel = SNMP_SEC_LEVEL_AUTHPRIV;
              /* set the authentication method to MD5 */
              session.securityAuthProto = usmHMACMD5AuthProtocol;
              session.securityAuthProtoLen = USM_AUTH_PROTO_MD5_LEN;
              session.securityAuthKeyLen = USM_AUTH_KU_LEN;
              if (generate_Ku(session.securityAuthProto,
              session.securityAuthProtoLen,
              (u_char *) item->snmpv3_authpassphrase, strlen(item->snmpv3_authpassphrase),
              session.securityAuthKey,
              &session.securityAuthKeyLen) != SNMPERR_SUCCESS)
              zbx_snprintf(error,sizeof(error),"Error generating Ku from authentication pass phrase.");
              zabbix_log( LOG_LEVEL_ERR, "%s", error);
              SET_MSG_RESULT(value, strdup(error));
              return NOTSUPPORTED;
              /* set the private method to DES */
              session.securityPrivProto = usmDESPrivProtocol;
              session.securityPrivProtoLen = USM_PRIV_PROTO_DES_LEN;
              session.securityPrivKeyLen = USM_PRIV_KU_LEN;
              (u_char *) item->snmpv3_privpassphrase, strlen(item->snmpv3_privpassphrase),
              session.securityPrivKey,
              &session.securityPrivKeyLen) != SNMPERR_SUCCESS)
              zbx_snprintf(error,sizeof(error),"Error generating Ku from priv pass phrase.");
              zabbix_log( LOG_LEVEL_DEBUG, "SNMPv3 [%[email protected]%s:%d]",
              session.securityName,
              session.peername,
              session.remote_port);
              Only MD5 and only DES.
                net-snmp don't support AES but SHA support can be added.
                  net-snmp support AES
                  And I sed that currently this features not supported.
                  Of course you can add everything, but now......
                    Huh is already support But for this need remove ucd-snmp support
                    Announcement
                    No announcement yet.
