[1.3.8] agentd dies with active check enabled.
  • zabbix_es
    • Apr 2007
    • 153
    With active check enabled zabbix_agentd dies after start.
    Here is the log with debug enabled:
    10072:20070529:121556 zabbix_agentd started. ZABBIX 1.3.8.
    10073:20070529:121556 zabbix_agentd collector started
    10074:20070529:121556 zabbix_agentd listener started
    10075:20070529:121556 zabbix_agentd listener started
    10076:20070529:121556 zabbix_agentd listener started
    10077:20070529:121556 zabbix_agentd active check started [192.168.0.4:10051]
    10077:20070529:121556 In init_active_metrics()
    10077:20070529:121556 In refresh_metrics('192.168.0.4',10051)
    10077:20070529:121556 get_active_checks('192.168.0.4',10051)
    10077:20070529:121556 Sending [ZBX_GET_ACTIVE_CHECKS
    linux1
    10077:20070529:121556 Before read
    10077:20070529:121556 In parse_list_of_checks('log[/var/log/mysqlFullBackup_linux1.log]:60:106741
    ZBX_EOF
    10077:20070529:121556 In disable_all_metrics()
    10077:20070529:121556 Parsed [log[/var/log/mysqlFullBackup_linux1.log]:60:106741]
    10077:20070529:121556 In add_check('log[/var/log/mysqlFullBackup_linux1.log]', 60, 106741)
    10077:20070529:121556 Parsed [ZBX_EOF]
    10077:20070529:121556 In process_active_checks('192.168.0.4',10051)
    10077:20070529:121556 In process log (/var/log/mysqlFullBackup_linux1.log,106741)
    10077:20070529:121556 XML before sending [<req><host>bGludXgx</host><key>bG9nWy92YXIvbG9nL215c3FsRnVsbEJhY2t1cF9s aW51eDEubG9nXQ==</key><data>MjkvMDUvMjAwNyAwMzoyNTowMyBteXNxbEZ1bGxC YWNrdXAuYmFzaDogQm9ycmFkbyAiL2RhdGEvYmFja3VwL2JhY2 t1cF9saW51eDFfb2xhcHNlZ3Vyb3NfMjAwNzA1MjVfMDAwMzE2 LnNxbC5neiIuCg==</data><lastlogsize>MTA2ODU2</lastlogsize></req>]
    10077:20070529:121556 OK
    10072:20070529:121556 One child process died. Exiting ...
    10072:20070529:121556 zbx_on_exit() called.
    10073:20070529:121556 Got signal. Exiting ...
    10075:20070529:121556 Got signal. Exiting ...
    10076:20070529:121556 Got signal. Exiting ...
    10074:20070529:121556 Got signal. Exiting ...
    10072:20070529:121558 ZABBIX Agent stopped
    If I disable active checks the agent runs normally.
  • JonB
    • Oct 2006
    • 63
    Check this thread
    Already reported and fixed in SVN.
    Jon
    • zabbix_es
      • Apr 2007
      • 153
      But this issue remains in [1.4]
      I saw that zabbix_agentd also dies in version 1.4.
      The issue appears when active check is enabled and there is a log file check.
      I don't know if you mean that this issue will be fixed in a future revision of 1.4.
      In that case is a bit pretentius to qualify version 1.4 as stable.
      • Eugene
        • Feb 2006
        • 57
        Please show latest 150 lines of zabbix log, with DebugLevel=4. For version 1.4
        • zabbix_es
          • Apr 2007
          • 153
          Now I can't reproduce the issue because my zabbix_server dies.
          See this thread:
          I will try reproduce as soon as I could start the server ...
