Frontend Bug?
  • predatorz
    • Mar 2007
    • 109
    Frontend Bug?
    Hi, Using Zabbix v1.4 now
    While updating/delete/create hosts items/triggers sometimes i get the below message or similar,
    Only variable references should be returned by reference[/var/www/html/include/xxxxx.inc.php:xxx]
    Only variable references should be returned by reference[/var/www/html/include/xxxx.inc.php:xxx]
    What is this error ?
    http://www.imagewoof.com/view_image/...abbixError.jpg
  • predatorz
    • Mar 2007
    • 109
    Zabbix v1.4
    the Flexible interval doesn't work...
    set item to delay 60, time:1-5,07:59-18:00
    but item checking still continue after 1800..
    Or did i mistake the use for flexible interval?
