Hi to the forum, (i apologize from now for my bad english),
i'm in stage in a enterprise (this study began in october...so i'm not so skilled...fresh new in professional, ops before pro i' m in stage...) and my project is to improve a monitoring system.
now after some days with zabbix (all works fine, also a imported check from nagios for the lotusnotes platform, maybe i can make my second post for this..) i'm in trouble with mysql; i have decided to install the 1.1 7 alpha version of zabbix on a suse enterprise edition 9.2; this sles is installed over vmware; i 've changed the time of the sles and reboot it and after zabbix decide to don't show all the data of all host and services, but only some with no criteria (some ftp services works some other not, some host have bother working and non working services); i'm sure the serveces i'm talking are up.
This final part of the log of zabbix_suckerd:
004151:20050408:043131 Timeout while receiving data from [xxx]
004151:20050408:043131 Getting value of [smtp_perf] from host [xxx] failed
004151:20050408:043131 The value is not stored in database.
004151:20050408:044844 Timeout while receiving data from [xxx]
004151:20050408:044844 Getting value of [smtp_perf] from host [xxx] failed
004151:20050408:044844 The value is not stored in database.
004146:20050408:044847 Got QUIT or INT or TERM or PIPE signal. Exiting...
004148:20050408:044847 Got QUIT or INT or TERM or PIPE signal. Exiting...
004149:20050408:044847 Got QUIT or INT or TERM or PIPE signal. Exiting...
004150:20050408:044847 Got QUIT or INT or TERM or PIPE signal. Exiting...
004151:20050408:044847 Got QUIT or INT or TERM or PIPE signal. Exiting...
From zabbix_server log
010053:20050412:161720 server #1 started [Alerter]
010054:20050412:161720 server #2 started [nodata() calculator]
010055:20050412:161720 server #3 started [ICMP pinger]
010051:20050412:161720 server #0 started [Housekeeper]
010057:20050412:161720 server #5 started [Trapper]
010061:20050412:161720 server #6 started [Trapper]
010062:20050412:161720 server #7 started [Trapper]
010063:20050412:161720 server #8 started [Trapper]
010064:20050412:161720 server #9 started [Trapper]
010056:20050412:161720 server #4 started [Sucker. SNMP:ON]
010056:20050412:161727 Evaluation of expression [({13002}=0)&({13003}=0)&({13004
}=0)] failed
010056:20050412:161728 Expression [({13002}=0)&({13003}=0)&({13004}=0)] cannot b
e evaluated.
010056:20050412:161735 Evaluation of expression [({13002}=0)&({13003}=0)&({13004
}=0)] failed
010056:20050412:161735 Expression [({13002}=0)&({13003}=0)&({13004}=0)] cannot b
e evaluated.
010056:20050412:161806 Evaluation of expression [({13002}=0)&({13003}=0)&({13004
}=0)] failed
010056:20050412:161806 Expression [({13002}=0)&({13003}=0)&({13004}=0)] cannot b
e evaluated.
I was thinking it was apropose the trigger ad i delete them. This error don't compare anymore but the problem persist. I also delete the smtp_perf services, but instead the zabbix seems to don't consider me...Mysql appears like freezed.
Probably my exposure isn't exhaustive.
thanks for the attention
regards
}=0)] failed
e evaluated.
}=0)] failed
e evaluated.
}=0)] failed
e evaluated.
regards
