1.1A7 zabbix_server does not reconnect if sql server dies
  • Wolfgang
    • Apr 2005
    • 116
    Using V1.1A7 the zabbix_server daemon does not automatically reconnect to the mysql database, if for some reason, mysql was down.
    So even monitoring the mysql database used _for zabbix_, _with zabbix_ wont help. I think this is a critical issue.
    I would suggest the following:
    -zabbix_server should automatically reconnect to the mysql postgresql server when the server is available again.
    -zabbix_server should notice the zabbix_administrator when sql becomes unavailable. The configuration of this special notification must be stored outside the sql-database of cause. The notification itself should easily be distingished by the admin from other notifications (facility, importance) since it indicates that monitoring is no longer available.
    -once the server is up again (i.e. sql link is reestablished), another notification shall be sent.
    -the log of this should be made available somewhere, maybe even merged back to the sql database once it is up again. For example into the section "events", or in a specific section zabbix_server "self monitoring".
    http://www.intellitrend.de
    Specialised in monitoring large environments and Zabbix API programming.
