startup script change proposal
  • richlv
    • Oct 2005
    • 3112
    with agent startup scripts, provided by zabbix, agent fails to start if pid file is there - even if no actual process is running.
    so, i'd like to porpose copyig misc/init.d/suse/9.3/zabbix_agentd to misc/init.d/suse/10/zabbix_agentd and improve it there.
    given that the script already handles the situation when pidfile exists, but the process is not running (by using checkproc), a very simple patch follows to allows zabbix_agentd startup even if system was not gracefully shutdown :
    --- zabbix_agentd       (revision 4387)
    +++ zabbix_agentd       (working copy)
    @@ -45,8 +45,13 @@
            echo -n "Starting ${NAME} "
            checkproc -p ${ZABBIX_PID} ${ZABBIX_BIN}
            case $? in
    -               0) echo -n "- Warning: ${NAME} already running! " ;;
    -               1) echo -n "- Warning: ${ZABBIX_PID} exists! " ;;
    +               0)
    +                   echo -n "- Warning: ${NAME} already running! "
    +               1)
    +                   echo -n "- Warning: ${ZABBIX_PID} exists! "
    +                   rm "$ZABBIX_PID"
            esac
            startproc -p ${ZABBIX_PID} -u zabbix ${ZABBIX_BIN}
    such a situation probably could be handled in zabbix_agentd itself, but this change is trivial and fast to apply.
    the problem also might be relevant for other startup scripts, but i don't want to mess up all of them
