Graph problems when using a timespan of 1 hour 1.4.2
  • Maximum
    • Sep 2006
    • 16
    I do not get any graphs plotted out if I use 1 hour time span, If I use 2 hours I sometimes get graphs and when I use 4 hours I always get graphs.
    The item that Im "graphing":
    Type: simple check
    Key: icmppingsec
    Type of information: Numeric (float)
    Units: ms
    Use multiplier: Custom mulitplier
    Custom multiplier: 1000
    update interval (in sec): 10
    Flexible intervals (sec): No flexible intervals
    Keep history (in days): 7
    Keep trends (in days): 365
    Status: Active
    Store value: As is
    Applications: -None-
    The above Item is created on a template which is linked to 12 hosts.
    I have no missing data when I "show the 500 latest values", and this behavior applies to all 12 hosts which are linked to the template.
    Ubuntu 6.06 LTS Server edition
    Kernel 2.6.15-28-server #1 SMP
    Mysql Ver 14.12 Distrib 5.0.22
    Apache 2.0.55
    PHP 5.1.2
    ZABBIX Sources Pre 1.4.2 (stable) 4457 12 Jul, 2007 from (www.zabbix.com/developers.php)
    Browser: IE7 / Firefox 2.0.0.4
    Best regards /Maximum
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    ZABBIX won't connect (draw a line, regions, anything) two points in graphs if there is no data in between within 4*"item refresh rate" seconds.
    In your case, if ZABBIX does not have data for every 4*10=40 seconds, it won't draw a line making the graph empty. Check your latest data. Does ZABBIX really get data every 10 seconds?
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
