[1.4.2svn]: ZBX_TCP_READ() failed [Interrupted system call]
  • kloczek
    • Jun 2006
    • 1771
    Zabbix agent is not avalaible.
    After enable debug messages on server side I see in server logs:
    6661:20070712:201224 Get value from agent failed. Error: ZBX_TCP_READ() failed [Interrupted system call]
    6661:20070712:201224 Host [backup02] will be checked after 60 seconds
  • kloczek
    • Jun 2006
    • 1771
    Similar when trying connect to zabbix agent 1.1.7:
    6661:20070712:202230 Timeout while answering request
    6661:20070712:202230 Get value from agent failed. Error: ZBX_TCP_READ() failed [Interrupted system call]
    6661:20070712:202230 Host [sql01]: another network error, wait for 15 seconds
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      Are you sure the pre1.4.2 is running?
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
      • manfro
        • Jun 2006
        • 25
        I've the same issue but I think is due to network configuration.
        If I try to reach the zabbix agent via an internal IP, without any firewall it works.
        Else if try the external, public IP address, passing through IPTables it doesn't work properly.
        IPTables is open on the correct ports and telnet on the agentd port from server and on the server port agentd works.
        • cbidwell
          • Aug 2006
          • 127
          Has anyone solved this issue here? I'm running several clients behind several different makes of firewalls, however I am running a Juniper Netscreen firewall that seems to be causing problems for my clients behind it. I can't figure out why. I've got tcp/10050 open as well as on my iptables. The client is reachable and zabbix server shows it available, however after a period of time, it would go unreachable again. Very strange. If I restart the zabbix_agentd service on the client, it will reestablish connectivity again. Can anyone help me with this?
          • skaze
            • Jun 2007
            • 19
            We just encountered this issue. Restarting the agent on the client kept the server up.
            • Alexei
              Founder, CEO
              • Sep 2004
              • 5654
              Probably the firewall have some kind of maximum number of established connections per minute/hour limit, so it just rejects everything after the point is reached.
              Alexei Vladishev
              My Twitter
