Zabbix 1.1 and PHP 4.1
  • joe
    • Nov 2004
    • 27
    Alexei,
    We have an older system which is running one of our Zabbix 1.1a7 installations. This system is running PHP4.1. There are 2 problem areas, both stemming from using <? to start a PHP codeblock, instead of <?php .
    So basically we're getting 2 sections of code which are not being executed, and just being displayed as HTML.
    1) include/html.inc.php, line 21
    2) hosts.php, line 320
    When I modified both of those lines to be <?php, then everything worked fine. Those are the only two places I found that were using <?.
    Simple fix.
    joe
  • aamen
    • Nov 2004
    look in php.ini, there is a key "short_open_tag = Off", change to on and everything must work.
    • joe
      • Nov 2004
      • 27
      Thanks for the reply. That would fix it I suppose, but I think the tags should be uniform. If you're going to use <?php in every place but 2, wouldn't it make more sense to fix those 2 places?
      However, thanks for the tip, I didn't know about that option!
      joe
