zabbix_agent(d) and Firewalls
  • timo
    • Apr 2005
    • 19
    I've now read quite a few forum posts and the documentation, and somebody mentioned that you can choose wether the agent should listen or push its data. However, I was unable to find the option where I can enable this.
    I need to monitor a server which is behind a firewall, so it's not actually monitoring, but reporting.
  • Wolfgang
    • Apr 2005
    • 116
    I think this option is not yet implemented and was discussed as a feature request for further versions.
    http://www.intellitrend.de
    Specialised in monitoring large environments and Zabbix API programming.
    • timo
      • Apr 2005
      • 19
      Nice to know, so I think I have to stick with an SSH tunnel.
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        This functionality will be availably pretty soon, in 1.1alpha8!
        Alexei Vladishev
        New York | Tokyo | Riga
        My Twitter
        • Wolfgang
          • Apr 2005
          • 116
          Good to hear
          Do you also consider any kind of enryption for the traffic between zabbix client and server for any future V1.1Alpha x release?
          • Alexei
            Founder, CEO
            • Sep 2004
            • 5654
            Yes, I do. Please, do not expect public key cryptography though. I will implement something simple (DES, 3DES, BLOWFISH, whatever).
            Alexei Vladishev
            My Twitter
            • Wolfgang
              • Apr 2005
              • 116
              Great
              As for the encryption type, symmetric encryption is fine. If i remeber correctly, bflowfish has the advantage of manageing unaligend data blocks within the algorithm, but i can be wrong.
