Total disk space
  • tbri
    • Apr 2005
    Total disk space
    Hello.
    disktotal[/] (Total disk space on partition /) shows 0 on all my servers! I'm running Zabbix 1.1 a7.
    Also the amount of free space is wrong, it shows M (Megabytes) where it should show G (Gigabytes).
    Is this a known error?
    -Torvald
  • habbers
    • May 2005
    same error for my reiserfs partitions
    There is this thread http://www.zabbix.com/forum/showthread.php?t=244 that outlines the problems with disk space showing zero. The inodes for my reiserfs partitions are shown as zero but disk space is ok except for the fact that I also have the same problem with the disk space for the other partitions showing kb where it should be showing MB and MB where is should be showing GB
    I am running the same version as you 1.1 a7 which i installed from the debian unstable apt repositry.
    • tbri
      • Apr 2005
      Thanks for the pointer
      I'll follow the other thread you mentioned. Thanks!
      I use both JFS and ReiserFS partitions, on SuSE 9.2.
      -Torvald
