Linked graphs in alpha8
  • christian
    • Apr 2005
    • 11
    I just upgraded from alpha7 to alpha8 and I tried to add a linked graph by adding it to my template host. Then I went to add items to the graph. For every device that uses the template host, I got the following output:
    Error in query [select hostid,host,useip,ip,port,status from hosts where hostid=] [You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1]ERROR EXECUTING: insert into graphs (name,width,height,yaxistype,yaxismin,yaxismax) values ('test1',900,200,0,0.0000,100.0000)
    This repeats over and over for every host. Then I get...
    Added graph test1 of linked host
    Added graph element to graph test1 of linked host
    Which also repeats over and over, followed by...
    No host with hostid=[]
    Repeats for every host as well.
    The graphs are not added to the linked hosts, despite the success message.
    Any suggestions?
    Thanks,
    Christian
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Please, give me some time to reproduce this.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • christian
      • Apr 2005
      • 11
      Thanks for looking into it.
      Christian
      • dpsantos
        • Mar 2005
        • 60
        Alexei, this happened with me too.
        Any help to do more debus just say...
        Duarte Santos
