Problem when Updating "Applications" for Item
  • Palmertree
    • Sep 2005
    • 746
    After you create an Item for a Host, and try to modifiy the "Applications". The changes are not saved when you return back to the Item properties. For a temporary work-around, "Mass-Update" can be used which works. :-)
    Alexei, Can we add this to the bug list? Thanks in advance.
  • Aly
    ZABBIX developer
    • May 2007
    • 1126
    Hmm it works fine to me. What rev., ver. you where using?
    Zabbix | ex GUI developer
    • Palmertree
      • Sep 2005
      • 746
      Aly,
      It looks like it has been fixed in the lastest build. Thanks for following up on this. :-) Your team fixes bugs very quick. Thanks for a great product.
