100% Speed Increase for the Daring..
  • Palmertree
    • Sep 2005
    • 746
    For the daring, I am running zabbix frontend 1.4.4 and using zabbix_server 1.5 beta for the collector/poller. I am seeing almost 100% increase in speed due to the database caching in 1.5 zabbix_server engine. This caching is putting lower over head on the database calls. I've been running this setup for about 30 days now and so far no problems. :-) I was also able to bump up the number of pollers to 20 without much impact on the database. Since there were to many problems with the beta 1.5 web frontend, I just ran the 1.4.4 web frontend with the Beta 1.5 Zabbix_Server until the kinks are worked out on the web code. Good job Zabbix developers on the 1.5 Zabbix_Server code, it rocks and is fast. :-)
  • Palmertree
    • Sep 2005
    • 746
    For those of you who want to try this, I forgot to mention that you must add a new row to the triggers table as follows.
    Table: triggers
    Field: type <- this is the actuall name of the field name
    Type: int
    Default: 0
    • Tenzer
      • Nov 2007
      • 316
      Hmm, that is maybe worth trying. I have a dedicated MySQL server which usually runs with 70%+ CPU usage, just because of Zabbix's MySQL queries.
      • Palmertree
        • Sep 2005
        • 746
        I was having the same issue as well until I started using the 1.5 zabbix_server engine.
        • noxis
          • Aug 2007
          • 145
          I am running that here now on our main system () however it has not had the desired effect The server is still only around 9% idle
          Edit: This is with Pre 1.5 (beta) revision 5408 if that makes a difference?
          • Alexei
            Founder, CEO
            • Sep 2004
            • 5654
            Just a reminder, the trunk code is not for use in production!
            Alexei Vladishev
            New York | Tokyo | Riga
            My Twitter
            • noxis
              • Aug 2007
              • 145
              Yea I have rolled back now but it was the only way to get it under serious load. I figured out why I was having such high cpu usage despite it being a Quad Core box... I had it set to 200 pollers
