Alpha10 template error
  • safl
    • May 2005
    • 103
    Hello Alexei,
    Once again, thx for a great piece of software! I love the frequent releases!
    I have a small correction to the Host.Win32 template
    The 'Item' checking "system[procrunning]" ain't supported by the Win32 agent.
    That is according to the 1.1 manual and my test setup (alpha10).
    - Simon
  • safl
    • May 2005
    • 103
    Plus the disktotal[c:] item has a custom multiplier of 0.
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      Thanks for this! I'm going to significantly change default templates prior to release of 1.1.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
      • safl
        • May 2005
        • 103
        Np. Looking forward to the next release!
        Btw is Active checks supported in the Win32 agent? Im desperately trying to make it work. But all i get is unknown status and nothing in the logs.
        • Alexei
          Founder, CEO
          • Sep 2004
          • 5654
          No, currently (1.1alpha10) active items are not supported by Win32 agent.
          Alexei Vladishev
          My Twitter
          • safl
            • May 2005
            • 103
            When will it be in win32 agent? I'm itching to test it
            • tuhl
              • May 2005
              • 17
              [disk*] in UNIX template
              There is also a wrong muliplier 0 for [disk*] in the UNIX template.
              That is the reason for getting no values on UNIX.
              The multiplier should be 1024.
