Compile errors with alpha on FBSD 4.11
  • racoon
    • Jun 2005
    i just tried to compile the current 1.1alpha10 with the following errors:
    gcc -o ../../bin/zabbix_agent -g -O2 -I../../include zabbix_agent.c sysinfo.c ../../include/log.c ../../include/cfg.c ../../include/security.c ../../include/snprintf.c ../../include/md5.c -Wall
    ../../include/snprintf.c: In function `dopr':
    ../../include/snprintf.c:182: warning: implicit declaration of function `__va_copy'
    ../../include/snprintf.c:180: warning: `args' might be used uninitialized in this function
    ../../include/snprintf.c: At top level:
    ../../include/snprintf.c:169: warning: `dopr' defined but not used
    /tmp/cc6N0Iea.o: In function `dopr':
    /usr/local/www/zabbix-1.1alpha10/src/zabbix_agent/../../include/snprintf.c:184: undefined reference to `__va_copy'
    *** Error code 1
    This happens since i first tried an alpha version with 1.1alpha7. The system is a FreeBSD 4.11-RELEASE-p9, which provides gcc-2.95.4 and GNU make 3.80.
    The configure script went fine.
    Any hints on that?
    Regards,
    Frank
    Last edited by racoon; 07-06-2005, 16:43. Reason: stubbed subject from 'alpha' to 'alpha10' for better overview
  • welshpjw
    • Mar 2005
    • 50
    check out the suggestion for Solaris/HPUX at:
    Post back if that works, please.
    • racoon
      • Jun 2005
      Sorry, doesn't seem to work - added
      LIBS = -I/usr/local/include -L/usr/local/lib -llber
      to src/zabbix_agent/Makefile and src/zabbix_server/Makefile but with no change in error.
      • Alexei
        Founder, CEO
        • Sep 2004
        • 5654
        Please, try to get and compile the latest snprintf.c from CVS.
        Alexei Vladishev
        New York | Tokyo | Riga
        My Twitter
        • welshpjw
          • Mar 2005
          • 50
          I was thinking more about the section that eliminates lines in the snprintf.c
          • racoon
            • Jun 2005
            welshpjw: Sorry, seems i missed the point - sorry :-)
            Alexei: the patched snprintf.c seems to work here.
            Thx, now i'm gonna try if it's running here, too
            Frank
