Zabbix 1.5 - Network Maps
  • Palmertree
    • Sep 2005
    • 746
    If you create a map element that is type host with a URL, a menu appears called "Tools" with selections of "Status of triggers". The user is not give the chance to click on the element to use the url that is link to the element. This might be how it is suppose to be setup so I am not sure if this is a bug or just a feature.
  • Aly
    ZABBIX developer
    • May 2007
    • 1126
    Mmm looking at the code.. this is a feature, but it's misleading users, so it's must be fixed I will think tomorrow how it's should be..
    May be some suggestions?
    Zabbix | ex GUI developer
    • Palmertree
      • Sep 2005
      • 746
      Hmm.. Not sure how hard it would be, but maybe make the URL field disappear in the configuration for the map element if they select Type "Host". Just a thought.
