Zabbix 1.5 - Invalid URLs
  • Palmertree
    • Sep 2005
    • 746
    Using HHTPWatch, I noticed that there are some invalid URLs either in the page_header or page_footer because it happens on every web page. This probably slows things down a little bit. The invalid URL is "https://:/". Below you will find the output of my HTTPWatch.
    https://host.domain.com/zabbix/
    https://host.domain.com/zabbix/css.css
    https://host.domain.com/zabbix/styles/default.css
    https://host.domain.com/zabbix/js/common.js
    https://host.domain.com/zabbix/styles/div.css
    https://host.domain.com/zabbix/styles/link.css
    https://host.domain.com/zabbix/styles/table.css
    https://host.domain.com/zabbix/styles/form.css
    https://host.domain.com/zabbix/styles/ul.css
    https://host.domain.com/zabbix/styles/p.css
    https://host.domain.com/zabbix/styles/popupmenu.css
    https://host.domain.com/zabbix/styles/bar.css
    https://host.domain.com/zabbix/styles/gmenu.css
    https://host.domain.com/zabbix/styles/sbox.css
    https://host.domain.com/zabbix/js/prototype.js
    https://:/
    https://:/
  • Aly
    ZABBIX developer
    • May 2007
    • 1126
    Mmm, my Apache access log doesn't show anything like that...
    Zabbix | ex GUI developer
    • Palmertree
      • Sep 2005
      • 746
      You would not see them in the apache logs because the url will never hit the server since there is no host.domain.com in the url. Apache should only show you hits I believe.
      • Aly
        ZABBIX developer
        • May 2007
        • 1126
        Reasonable notice.. But I don't see such queries going from my browser either.
        Maybe asynchronous queries is shown like that?!
        • Palmertree
          • Sep 2005
          • 746
          I wonder if this is https specific. prototype.js is last thing loaded before the https://:/.
          I noticed the following in prototype.js:
          isSameOrigin: function() {
          var m = this.url.match(/^\s*https?:\/\/[^\/]*/);
          return !m || (m[0] == '#{protocol}//#{domain}#{port}'.interpolate({
          protocol: location.protocol,
          domain: document.domain,
          port: location.port ? ':' + location.port : ''
          I wonder if this is causing this?
          • Aly
            ZABBIX developer
            • May 2007
            • 1126
            There is only comparisons, no query.
            • Palmertree
              • Sep 2005
              • 746
              Good point. I will keep looking.
              • Palmertree
                • Sep 2005
                • 746
                If I comment out prototype.js in pageheader.inc.php the https://:/ links go away. I am go to start commenting out things in the prototype.js file itself to try and determine where it is in the code.
                • Palmertree
                  • Sep 2005
                  • 746
                  I found the problem.
                  The problem does not occur when using Version 1.5.1.2 of prototype.js but occurs in version 1.6.0.0 and above. The problem is due to the following line:
                  document.write("<script id=__onDOMContentLoaded defer src=//:><\/script>");
                  Here is some links that reference the same issue with other apps using the JavaScript:
                  To correct the problem I modified the following in prototype.js:
                      document.write("<script id=__onDOMContentLoaded defer [COLOR="red"]src=//:[/COLOR]><\/script>");
                      $("__onDOMContentLoaded").onreadystatechange = function() {
                        if (this.readyState == "complete") {
                          this.onreadystatechange = null;
                          fireContentLoadedEvent();
                      document.write("<script id=__onDOMContentLoaded defer [COLOR="Red"]src=javascript:void(0)[/COLOR]><\/script>");
                  I am not seeing the https://:/ invalid urls anymore with httpwatch.
                  • Aly
                    ZABBIX developer
                    • May 2007
                    • 1126
                    Are thous requests seen only when open an encrypted pages or a simple pages too? Because I really can't catch them, at least on unencrypted host.
                    • Palmertree
                      • Sep 2005
                      • 746
                      Good question. I will turn off https and see. The request will never hit the web server since the url is invalid. Not sure if you every used httpwatch before but you can download a stripped down version for free I believe. It's a very usefull program. :-)
                      Download HttpWatch 16.x for Google Chrome 105+ and Microsoft Edge 105+. The free Basic Edition installs in minutes on Windows 10 or later.
                      Update Post: It looks like the free version is only good for a limited number of well known sites. :-(
                      I will test http and report my findings.
                      • Aly
                        ZABBIX developer
                        • May 2007
                        • 1126
                        I monitor queries not on the server but directly from the browser, this as I understood is IE related problem, on IE I use "The Fiddler" tool to monitor connections.
                        • Palmertree
                          • Sep 2005
                          • 746
                          Cool. I've used Fiddler too and it is also a good resource tool. This sounds like it must be a https type problem. :-)
