[1.5] First impressions
  • NOB
    • Mar 2007
    • 469
    Hi
    I installed ZABBIX 1.5 (fresh install) today.
    I like some small changes in the GUI very much:
    1. The log output of the operations (deleting templates, changing items, ...) is now in a separate field with a scrollbar. So the top is no longer scrolled off screen !
    2. Logout was moved to the right place (top right), where other web interfaces put it too.
    3. Introduction of a history bar
    4. Editing of translations on a web page instead of a php file
    I encountered the same problem as has already been mentioned
    with the templates (proxyid).
    Another problem I found with the XML import.
    The export of Templates now includes sub-templates, i.e. if one
    template consists of several others there names are now included
    in the export. Very Good
    Trying to import those, however, a message like "Template-name: access denied" appears for every one
    I hit the semaphore problem, too.
    I couldn't find the dashboard (under Monitoring ?). Is it only available for a "normal" user ?
    In defines.inc.php I changed the BLINK_PERIOD to 0 and I noticed
    a new variable called "TRIGGER_FALSE_PERIOD" which is set to
    the same 1800 (seconds ?).
    What does this mean ?
    Thanks for the good work so far and, of course, for listening
    to the request of your users.
    Regards
    Norbert.
    Edit: found the dashboard in R5512. I'm impressed. This covers almost all what our operations people requested.
    Thanks a lot
