Supported migration paths
  • toteleiche
    • Mar 2008
    • 9
    Hi there
    What will be the supported migration paths in Zabbix 1.6 ?
    Is it recommended to migrate a 1.0 installation over the 1.0 => 1.1, 1.1 => 1.4 Versions or will there be disadvantages ?
    Have a nice day
  • bbrendon
    • Sep 2005
    • 873
    If you want to get to 1.6, I'm pretty sure you can only upgrade to 1.6 from 1.4.
    If you're running v1.0, it might be easier to start from scratch using 1.6. The upgrade is really just a bunch of SQL files though, so it should be pretty easy but may take awhile.
    Unofficial Zabbix Expert
    Blog, Corporate Site
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      Upgrade from 1.4 to 1.6 is supposed to be very straightforward.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
