I could not compile Zabbix 1.5.2 with the ldap option in ./configure and static mode :
These errors appear in config.log :
And when I want to make a "make install", the process abort with these :
If I compile without the static option, the make install work...
I need the static option to install easly the zabbix server in all my zabbix servers...
Help please...
./configure --with-ldap --with-net-snmp --with-mysql --enable-agent --enable-server --enable-static --prefix=/usr/local/zabbix/
/usr/lib/libcurl.a(ldap.o): In function `Curl_ldap': warning: Using 'dlopen' in statically linked applications requires at runtime the shared libraries from the glibc version used for linking
/usr/lib/libcurl.a(netrc.o): In function `Curl_parsenetrc': warning: Using 'getpwuid' in statically linked applications requires at runtime the shared libraries from the glibc version used for linking
collect2: ld returned 1 exit status
make[2]: *** [zabbix_agent] Error 1
make[2]: Leaving directory `/home/jean/Temp/zabbix-1.5.2/src/zabbix_agent'
make[1]: *** [install-recursive] Error 1
make[1]: Leaving directory `/home/jean/Temp/zabbix-1.5.2/src'
make: *** [install-recursive] Error 1
Help please...
