Zabbix Process Monitoring in 1.8.5: timer
  • untergeek
    • Jun 2009
    • 512
    I just upgraded to 1.8.5 and love the new process monitoring. I immediately set to creating some monitoring to see if I could alter my number of Pollers, Pingers, Trappers, Syncers, etc. to streamline the install and hopefully reduce unnecessary resource consumption.
    I found something unusual very quickly. In the 12 hours since I got everything running, my timer process has been hovering around 50% busy, with some spikes to 70%, and one spike to 100%!
    The graph for 12 hours reveals this:
    Last Min Avg.   Max
    72   42   49.01 100
    The documentation says this:
    timer - process for evaluation of time-related trigger functions and maintenances
    Our current setup is:
    Zabbix server is running	Yes	localhost:10051
    Number of hosts (monitored/not monitored/templates)	740	642 / 0 / 98
    Number of items (monitored/disabled/not supported)	26807	26712 / 45 / 50
    Number of triggers (enabled/disabled)[problem/unknown/ok]	7187	7166 / 21  [2 / 197 / 6967]
    Number of users (online)	60	4
    Required server performance, new values per second	434.64	 -
    Note: Most of the unknown triggers are from checks which only run daily and got missed by the Zabbix server restart. They're trivial (What version of zabbix_agentd, etc).
    I created some scripts which automate the creation of maintenance windows. I built this based around the php code in the UI. It's worked well for us.
    At any rate, I cleaned out the old crufty maintenances and it didn't reduce the timer usage at all (which was not unexpected). That leaves me to think that it's all about the triggers with time functions.
    Question: What happens to trigger checks when the timer process is maxed out? There's no option to add timers without hacking the code (which I wouldn't do), so I would like to know how such a high amount of load would be handled.
    It is feasible that if we doubled our current workload that would put much more strain on the timer process. Is anyone else operating under a similar strain to their timer process? I'm very curious now that 1.8.5 allows for trending and monitoring of this.
    Last edited by untergeek; 20-04-2011, 16:41. Reason: Added emphasis and 100% spike.
  • richlv
    • Oct 2005
    • 3112
    very interesting stats. i suspect that timer process might also need data from the database if you use something like "avg(largenumber) & nodata()".
    any of your triggers using functions with parameters that would request lots of historic data (along with time based functions) ?
    • untergeek
      • Jun 2009
      • 512
      I will do some digging. I would like to come back with more than "a few of these" or "some like this."
      I can say, in the interim, that we have a fair number of triggers which do checks over the last 600 seconds for nodata checks.
