Hi
I intend to migrate from single zabbix server to distributed model.
Currently deployment:
Hardware:
RAM: 16 GB
HDD: 1 HDD (SATA - 7200 RPM)
CPU: Quad Core - Intel(R) Xeon(R) CPU E3-1230 V2 @ 3.30GHz
Software:
Zabbix: 1.8.3
Hosts: 400(next month apprx: 800)
Items: 100K(next month approx: 150K)
triggers: 0 (next month approx: 5000)
NVPS: ~400
Queue Performance: more than 200 items with 10 minute delay
DB: Mysql - InnoDB
Size DB: 40GB
I decided to add another hardware with the same spec in order to create distributed model
But I have some concern about migrate from standard zabbix server to distributed model because this server is production.
My concerns:
1- which solution is sophisticated for my needs,Node or Proxy.of course I do not have good understanding about difference of them
2- If I choose Node distributed model, Is there any problem in converting standard database to node database for 40GB size?for example lost data or corruption database.
3- what type data does child node send to master node?
4- Does Master Node have copy of all child's data (including configuration and history data)?
5- Can admin config node via master web UI?for example add new host or create trigger or any configuration from master node.
6- Is it possible that move hosts from currently standard zabbix server to child node? if so, How can I do it?
7- Is there any limitation on converting standard zabbix server to a master node?
8- Can admin access via graph and other data about one host that are monitored by child node?
Hardware:
RAM: 16 GB
Software:
Zabbix: 1.8.3
NVPS: ~400
DB: Mysql - InnoDB
Size DB: 40GB
My concerns:
), it better to point to documentation, see #8
