Oracle performance tuning (Zabbix 2.0)
  • rrupp
    • Jul 2012
    • 21
    Edit: For some reason the forum isn't allowing me to embed links (complains about to many even with just one link) so I had to obscure the link names.
    Hey, I just wanted to start a thread about tuning Oracle to work better with Zabbix when dealing with 1000nvps+ and hopefully get some input from others that have already done this (I'm just in a testing phased right now) - I'm not a DBA so bare with me! I'd also like to get feedback from others that are currently using Oracle for large environments - I think most people use MySQL. So I'll start with different points:
    1. Session/process usage
    We were seeing high session usage inside of Oracle. Looking into this it seems like there were two factors:
    A) For each poller process Zabbix has a dedicated connection to Oracle
    B) The frontend was causing a high number of sessions
    Investigating into this further I found the issue ZBX-6160, this fix is unfortunately only on trunk but I manually backported this issue to 2.0 and it seems to have resolved the issue with persistent connections caused by the frontend. So basically at this point we just need to make sure we have max sessions/processes high enough to account for the 1 per poller model and manually backport the frontend fix.
    2. SQL Hit ratio/variable binding issue
    So to monitor Zabbix I installed Orabbix. One of the things Orabbix is complaining about is the SQL hit ratio. Looking at this statistic we're averaging around a 15% hit ratio. I started investigating this and I believe it's referring not being able to pull up cached SQL plans possibly due to literals being used instead of bind variables. This then lead me to this -www.zabbix.com/forum/showthread.php?t=25892 - which has a corresponding Jira for it . In that Jira it mentions this can partially be overcome by setting "shared_cursor=force" - after setting this though that SQL hit ratio metric has not improved (maybe I'm interpreting this metric incorrectly). Any suggestions here?
    3. Table partitioning
    I plan to use table partitioning which is discussed for Oracle specifically here -http://remigium.blogspot.com/2012/10/zabbix-on-oracle-few-notes.html - I haven't had a chance to try this yet though (use of interval partitioning specifically)
    Any other useful information that people using Oracle in a large environment are doing?
  • netflash
    • May 2013
    I plan to do partitioning to.
    Did you get more information about this issue ?
    • mtneagle
      • Oct 2011
      Set Oracle Free Lists to Max
      We are still on 1.8.6 with Oracle 11.0.1, but despite beefy server and fast storage, were having spotty graphs and 100% busy syncers and bogus alerts etc. Basically the flood of item data was starting to overwhelming us.
      We found that the Oracle was not 'self tuning' properly for parallel table operations. We had fantastic performance once we "set freelists to the max, 23" for the history table, per our DBA. I can get further details if people are interested.
      This might not help you, and 23 might not be the right setting for everyone, and maybe proceeding with a technique as described here, would be better:
      Now we can start thinking about Zabbix 2.0
      • netflash
        • May 2013
        I get a lot of performance after I made partitioned.
        HOWTO will be on my github account in a couple weeks.
        GitHub is where people build software. More than 225 million people use GitHub to discover, fork, and contribute to over 800 million projects.
        Now you can look through draft https://github.com/netflash/zabbix-o...S/partitioning
