Partitioning PostgreSQL 9.1 on running environment
  • shayani
    • Oct 2005
    Hi all.
    I have a Zabbix server, with 1 proxy (for now):
    332 hosts
    29055 items
    348 NVPS
    I use different servers for Zabbix server and PostgreSQL 9.1
    The PostgreSQL server is a VM (in a cluster) with 4 CPUs, 8GB RAM and connected to a HP Storage (FC Disks, no SSD). The storage performance is OK for general use, but for PostgreSQL, is a bottleneck. The tables are getting huge and a simple Housekeeping (limited at MaxHousekeeperDelete=25) takes almost 1 hour. If I increase this value, god save me!!!
    So, I read a lot about partitioning PostgreSQL to get a better performance, but is it possible to do it in a running environment? How to do it?
  • f.koch
    • Feb 2010
    • 85
    hi,
    you can take a look at https://github.com/keithf4/pg_partman
    regards
    • shayani
      • Oct 2005
      Just to inform that I had great success with this technique: https://www.zabbix.org/wiki/Docs/how...topartitioning
      • mrjoshuap
        • Nov 2013
        Originally posted by f.koch
        hi,
        regards
        Do you have any recommendations on using pg_partman? It seems to only work with id, not time based partitioning... Have you tried implementing it?
        Thanks!
        • Jason
          • Nov 2007
          • 431
          For time based i used this and it works rather well for us. https://www.zabbix.org/wiki/Docs/how...topartitioning
          Not sure how it could be adapted for pre-existing data unless you used select into to move chunks of the data into partition tables manually?
