Is it large or not and what to do best?
  • Gutsycat
    • Nov 2017
    • 72
    Hello.
    My current instance is:
    2 Xeon
    64Gb RAM
    15Tb SAS disks
    One server with zabbix and mysql database 1.8Tb on it.
    Also I have ~1k of hosts and 50-60k items
    I'm stuck with problem.
    When I start mysqlcheck -A or mariabackup --backup --incremental-basedir=... after some time zabbix server failed.
    Is it time to plan another architecture?
    Does 1.8Tb of mysql data needs to be clustered?
  • Mike2K
    • Oct 2018
    • 60
    How many NVPS do you have ? and do you ever cleanup old data ? whats the history and trend settings of your checks ?
    • Gutsycat
      • Nov 2017
      • 72
      I have about 300 nvps
      • Mike2K
        • Oct 2018
        • 60
        That's not large...can you show us the zabbix performance graph ? Does the zabbix log show slow queries ?
        • Gutsycat
          • Nov 2017
          • 72
          Zabbix log no but mariadb does.
          No we CAN NOT do such thing.
          • DmitryL
            • May 2016
            • 278
            Add --single-transaction to your mysqldump command.
            But even better, choose different backup tools.
            • Mike2K
              • Oct 2018
              • 60
              Can you explain why you can't cleanup old data? Why would you need to keep everything?
              • Gutsycat
                • Nov 2017
                • 72
                Yes, I can. Our business process expects to store data for 5 years, now only 2 years have passed for now.
                • Jason
                  • Nov 2007
                  • 431
                  Then why not export the old data out from zabbix into elasticdb? That's built in to version 4.0 onwards.
                  Do you really need to keep all data or just trends? If just the trends then that's not too bad, but all of the data is going to be massive and I'd argue not necessary unless you really really need to know what the state was at every moment in time for 5 years...
                  • LenR
                    • Sep 2009
                    • 1011
                    There should be an error message at the time of the crash, without it, we're just guessing.
                    Did you partition your database? Replace housekeeper with partition management as recommended elsewhere.
                    Did you tune mysql? Things like large pages and innodb_buffer_pool.
                    • Gutsycat
                      • Nov 2017
                      • 72
                      Maybe run replica DB? You can always do a backup of replica without worrying about production DB.
                      Yes, we finally did it. But I think that it is kind of workaround for our deployment.
                      No any message... Zabbix just shows yellow balloon at the bottom and nothing in the log.
                      Yes we are.
                      Sure.
                      Could the problem being with custom external check program which starts 1000 times and reads many of config files?
                      • bbrendon
                        • Sep 2005
                        • 873
                        Gutsycat, Dmitryb already gave you the answer. You should listen instead of chasing your tail.
                        Unofficial Zabbix Expert
                        Blog, Corporate Site
