Hi! I m trying to install zabix on a centos 6.5 server
the problem si that the zabbix_server do no listen
and cannot create mysql connection...
but: i can connect by doing mysql -u zabbix zabbix -p and the show tables;
looks ok
my settings are:
[root@monitor zabbix]# grep ^[0-9,A-F,a-f] /etc/zabbix/zabbix_server.conf
DebugLevel=2
DBHost=localhost
DBName=zabbix
DBUser=zabbix
DBPassword='PAROLA_SECRETA'
DBSocket=/var/lib/mysql/mysql.sock
AlertScriptsPath=/usr/lib/zabbix/alertscripts
ExternalScripts=/usr/lib/zabbix/externalscripts
FpingLocation=/usr/sbin/fping
Fping6Location=/usr/sbin/fping6
AllowRoot=0
[root@monitor web]# cat zabbix.conf.php
<?php
// Zabbix GUI configuration file
global $DB;
$DB['TYPE'] = 'MYSQL';
$DB['SERVER'] = 'localhost';
$DB['PORT'] = '3306';
$DB['DATABASE'] = 'zabbix';
$DB['USER'] = 'zabbix';
$DB['PASSWORD'] = 'PAROLA_SECRETA';
// SCHEMA is relevant only for IBM_DB2 database
$DB['SCHEMA'] = '';
$ZBX_SERVER = 'localhost';
$ZBX_SERVER_PORT = '10051';
$ZBX_SERVER_NAME = '';
$IMAGE_FORMAT_DEFAULT = IMAGE_FORMAT_PNG;
does anyone have any idea why this is not working?
i found no information in any installation turorial...
Thanks a lot!!
Adrian
looks ok
my settings are:
DebugLevel=2
DBHost=localhost
DBName=zabbix
DBUser=zabbix
AllowRoot=0
<?php
global $DB;
$DB['SCHEMA'] = '';
Thanks a lot!!
Adrian
