Problem with mysql 8.0.17 innodb cluster tables
  • mellis
    • Oct 2017
    • 145
    I am finishing up a setup of a MySQL InnoDB cluster and I am seeing an error when the zabbix server tries an insert in to the history tables. I am using the 4.4a3 zabbix
    history
    history_uint
    history_str
    history_log
    history_text
    I also saw this in the dbversion table
    The Error message:
    [Z3005] query failed: [3098] The table does not comply with the requirements by an external plugin. [insert into history_unit (itemid, clock,ns,value) values (23662, 1569438442, 841640353,0);
    When I look at these tables I find it does not have a primary key, which I believe is required for the innodb cluster.
    I am wondering what is the recommended way to create a primary key?
