1600NVPS - scaling to 3000NVPS
  • thesubmitter
    • Feb 2012
    • 42
    I am in the process of replacing a zabbix environment with 1600NVPS (v3. 4)and retaining only 10 days of data to a system that should store at least 90 days of history, 1 year of events nad 3 years of trends (v5). I also want to be able to handle 3000NVPS if necessary.
    Money isn't really an issue but I want to be close to the mark.
    I'm planning for:
    6TB SSD (4x3.2TB) with HP SmartArray MR BBC Card either Raid 10 or Raid 5
    1 Xeon Gold 6230R
    1 256GB Ram (I have money)
    -I am planning to use timeseriesDB
    -I am not planning for HA (or if I have a backup it will be asynchronous and a DR failover type)
    -I will have one machine as DB and Server. I think at the specs I am putting up I should be fine and it eliminates network latency issues.
    Am I missing somehting....
    Thanks in Advance!
  • vendrusculo
    • Jul 2015
    • 26
    Hi!
    Looks like you are buying a bazooka to kill ants
    I have 7900+ vps, 3 days of history (minute), 1 year of trends (hourly) and using a postgres with partitioned tables (less efficient than timescaleDB) and the problem is always on the database! The database size today is 1.1TB
    Zabbix by it self will not be a problem with small machines even using virtual machines or docker, probably you will need at maximum a proxy to keep your queue clean...
    I would say to be prepare to handle the database needs instead spend too much time on Zabbix
    Thanks,
    Leo
    • thesubmitter
      • Feb 2012
      • 42
      The server will be my DB too and I will add as many proxies as needed
