Dynamic datasets for single graph item
  • samarcos
    • May 2021
    • 17
    I am trying to create a graph widget that would show all the devices under the same template or group, and display a single item.
    example: I have 4 pfsense routers, I have a graph that displays the item: Outgoing network traffic from those 4 routers,
    This gives me a single graph that shows 4 colored lines, if one of those lines changes, then I can see there is an issue.
    I have this same graph for the Incoming network traffic, Processor Load, running Processes and Available Memory.
    I would like to do this same kind of graph for Memory Free, CPU Load and Storage Used Percentage, but for my windows Workstations. This would show me when a single machine is peaking in cpu usage or low on storage.
    I could manually go and add them all, but we have lots of them and they are replaced often.
    If i can create the graph from all the devices from a template, then they would get added and removed dynamically.
    Thanks.
