Minimize zabbix network traffic
  • jozovo
    • Feb 2021
    ​​Zabbix generates too many network traffic and overloades our router. We would like to have external proxies which would send data in 15 min intervals. I can change DataSenderFrequency, ConfigFrequency, but I have no option for Heartbeat frequency. How can I change heartbeat frequency from 1s to 15m? Is it possible to do that some way? We use active proxies (passive mode is not possible). We are testing 6.4 version now. Thank you for your answers.
  • Markku
    • Sep 2018
    • 1786
    It's documented as:
    DataSenderFrequency no 1-3600 1 Proxy will send collected data to the server every N seconds. Note that active proxy will still poll Zabbix server every second for remote command tasks.
    Active proxy parameter. Ignored for passive proxies (see ProxyMode parameter).
    It's very little traffic though.
    Markku
    • jozovo
      jozovo commented
      Yes, we have this option set to 900, but there is still too many heartbeat traffic. The proxy sends a heartbeat signal every second, there is almost no data, but processing overloads a router's security applications and its log as we have too many proxies.We would like to send a heartbeat signal in 15 minute interval.
  • Markku
    • Sep 2018
    • 1786
    Yeah as shown it is by design to ensure remote commands are executed timely. You can always open an enhancement ticket on support.zabbix.com if you like. Or reconfigure your router.
    Markku
    • jozovo
      jozovo commented
      The router reconfiguration is the solution, if there is no other "Zabbix" way. We would like to use more system solution, but if there is no other possibility, we will to do that. Thank you for info.
