Hello!
I have a fairly large zabbix environment:
4081 hosts
344991 Items
2339 NVPS
12 proxies
For about 2000 hosts, I want to run an external check, every 60 seconds, which should return in under 15 seconds.
Are these like web tests, where a proxy will perform the check, or do all checks happen from the main zabbix collector?
Which pool of threads perform external checks? I am assuming it's normal pollers.
The documentation states not to "overuse" external checks, for risk of degrading performance, so I am wondering how well they scale.
My collector and proxies are mostly high spec (2x6 core hyperthreaded W 128GB RAM). Is the degradation in performance related to CPU, Disk IO, RAM, etc?
Which spec would I increase to be able to run more external checks?
Do external checks still obey the "timeout=" option defined in zabbix_server.conf or zabbix_proxy.conf?
I am guessing that if the script were to become broken, then the poller threads would each lock up for 15 seconds while performing the test.
4081 hosts
344991 Items
2339 NVPS
12 proxies
