Hy guys!
Some time ago I've created ZbxWizz a tool I built out of necessity while working on a large Zabbix environment.
At that time I've also made a post about the launch, here on the forum, but I must confess that the presentation sucked big time. Then I've realized that any tool is as good as its user manual and that the presentation counts a lot.
Today I've finally finished putting together a website with instructions about how to get the tool, install it and get started using it. There is also documentation available, but it's still a work in progress.
Now I'm re-releasing the hole thing, hopefully in a cleaner and cleared manner, so that you guys can actually start testing (and using) this tool, which, at least for me and my colleagues, made a huge difference in the way we handle out daily tasks.
As a short intro, ZbxWizz gives you a spreadsheet-like interface where you can:
Project site: https://zbxwizz.app
Code: GitHub
If you're working with Zabbix and want to handle bulk config more easily, try it out.
Feedback is more than welcome!
- Import data from CSV or directly from the Zabbix API
- Filter, sort, and apply transformations with JavaScript
- Push changes back into Zabbix via API
Code: GitHub
