ARG!!! Zabbixisms... Post your's here!
  • nelsonab
    • Sep 2006
    • 1233
    I'm sure we've all come across something that seems straightforward, but when we try and figure out what's going wrong it's not straightforward, but when we're done, it's really quite simple. Here is one such situation. Post your's here...
    You'd think that after having been bit by this once before I'd remember... But I guess not. So I'll post this here just in case it may help someone else down the road.
    Problem: Email notifications of triggers are not being sent.
    Solution:
    Verify trigger is working (did this, and it is)
    Verify Action is setup correctly (yep!)
    Verify Email is setup in "Media Types" (yep!)
    Check mail logs (WTF are these "lost connection after CONNECT from localhost" errors?)
    Turns out it's a multi-step problem. ARG!!! Damm you zabbix! <pumps fist in air>
    Let's step back a bit. Turns out the action I had setup was connected to the trigger, but not the trigger on the host but the trigger in the template. Ok so I forgot that linking to a trigger within a template does not work (but you'd think it would!), you must use the "like" evaluation not the "=" evaluation... So while the trigger was happening and I would see it in the overview the action would not fire as it was evaluating to the template which will NEVER change state. Ok so I change the action expression to "like", add a description and test my trigger again. BAM! I get alerts! w00t!
    Ahh but what about that "lost connection after CONNECT from localhost" error. Turns out it's something put in by Alexei and others to throw you off, and make you think you're upside down when you're really inside out. In reality it's the net.tcp.service key checking to see if the SMTP server is up and running. Why yes thank you, it is!
    So if you're having problems getting actions to send email alerts using Postfix or whatever check to be sure you're action is tied to an alert that will actually send. ie Don't link to a template. DOH! Next when you see "lost connection after CONNECT from localhost" in your Postfix log files you can in all likelihood ignore them.
    RHCE, author of zbxapi
  • bbrendon
    • Sep 2005
    • 873
    LOL. Nice rant
    Unofficial Zabbix Expert
    Blog, Corporate Site
    • Alexei
      Founder, CEO
      • Sep 2004
      • 5654
      BTW Linking actions to a template will be supported in 1.6. Actually it is already implemented.
      Alexei Vladishev
      New York | Tokyo | Riga
      My Twitter
      • nelsonab
        • Sep 2006
        • 1233
        Yeah!!!!!!!!!
        • cstackpole
          • Oct 2006
          • 225
          SWEET! Thank you! Thank you! Thank you! That news just made my day (even if it was posted some time ago)
          • noxis
            • Aug 2007
            • 145
            The zabbisms that I have come across are arse backwards logic. To me you should trigger when a partition becomes 99% full not 1% empty
            A server being "ON" is apparently a bad thing
            • balu
              • Aug 2008
              Does anyone know if Jabber notifications work in 1.6? I was not able to get them running at all in 1.4 :-(
              Ah, I will upgrade anyway...
              Balu
