I have a question about zabbix installations.
In my case I must have stable and performance monitoring system without loosing data becouse of unstable connection between zabbix agent and server. So i decided to install separate childe nodes with agent on every monitoring system and one master node. On master node machine I have Apache with php so I can use zabbix web interface to end configuration (local and remote node - following guide) but on childe node machines I have not Apache (it's impossible to install apache). And this is the question - how can I configure childe nodes without web interface? It is possible to do it properly?
And one more question, how can I change default user (zabbix) to run agent and server?
