can somebody tell me how to do the following :
1) Create a website checker for the 5 domains we run? Not by using a trigger or item by host, but preferbly create a host per website.
So when clicking monitoring we get a list of hosts with there triggers being green/white/unavailable/red. Is there a way to add the websites there as hosts?
If this isn't possible, I have tried adding a item for a certain server for each website like :
{Paris:net.tcp.service.perf[http,80.85.129.113,80].last(0)}<1
This doesn't work properly for some reason. I would prefer a www.website.com instead of ip anyway.
If it's not possible to add these checks as a host, can somebody tell me how to get a website check working correctly for a windows host with this item?
2) Check to see if 4 other websites with https (port 443) work.
Would it be possible to make a trigger like : if asked for username and password dialogue = service is up, if no reply on this https port = service is down?
3) Anybody using ServersCheck with zabbix? I'm using this software with a serial based tempature meter. Would be awesome if I could get the temp/humidity sensors to work with zabbix.
4) I would like to have all windows event logs with a warning or error be sent to my email. Has anybody got zabbix to get windows eventlogs and send them to email/media? Is there a FAQ or HowTo available for this?
