monitoring with SNMP: Only few values shown
  • just2blue4u
    • Apr 2006
    • 347
    I am monitoring many DELL PE850, 860 and 2950 Servers with zabbix.
    I query for CPU and Mainboard Temp, Fan speed, Chassis model, and many more.
    Zabbix displays this values correctly for all servers, but for one it doesn't list some.
    I don't know how this can be, because:
    - Hardware is the same (PowerEdge 850)
    - Software is the same (Fedora Core 5, Zabbix 1.4.5, net-snmp 5.3-4.2, OpenManage 5.4.0)
    - Configuration is the same (script)
    - Zabbix item is the same (template)
    Querying one value that's not shown in zabbix (chassis model):
    # snmpwalk -c public -v1 localhost 1.3.6.1.4.1.674.10892.1.300.10.1.9.1
    SNMPv2-SMI::enterprises.674.10892.1.300.10.1.9.1 = STRING: "PowerEdge 850"
    and remote from the server:
    # snmpwalk -c public -v1 <host> 1.3.6.1.4.1.674.10892.1.300.10.1.9.1
    Here's the list of items that are not shown for the problem host:
    "BIOS Version", "CPU Anzahl aktive Kerne (CPU 1)",
    "CPU Anzahl aktive Kerne (CPU 2)", "CPU Info (CPU 2)",
    "Gehäuse Modell",
    "Lüfter1 U/Min",
    "Lüfter2 U/Min",
    "Lüfter3 U/Min",
    "OM: Software Version",
    "PE: Temp 1 (Wert ist)",
    "PE: Temp 2 (Name)", "
    PE: Temp 2 (Wert max)",
    "Service Tag"
    All are queried via SNMP.
    Background: There are 2 Temp sensors and 3 items for each:
    - Sensor label ("Name")
    - The queried value ("Wert ist")
    - Dell's defined maximum allowed value for that sensor ("Wert max")
    Interesting is, that "PE: Temp 1 (Wert ist)" can't be monitored but "PE: Temp 2 (Wert ist)" can.
    Same with "PE: Temp 2 (Wert max)" (can't) and "PE: Temp 1 (Wert max)" (can be queried)
    Who has any idea?
    I'm really confused! this is the first of about 20 (identical) hosts that has this behaviour...
    Big ZABBIX is watching you!
    (... and my 48 hosts, 4513 items, 1280 triggers via zabbix v1.6 on CentOS 5.0)
  • just2blue4u
    • Apr 2006
    • 347
    Solved!
    I noticed the CPU load being a little higher then normal. So i restarted the zabbix server and suddenly everything was fine again!
    Too bad i realize it this late...
