How to get status (up/down) for hp procurve switch
  • just2blue4u
    • Apr 2006
    • 347
    Hi!
    I'm checking our 2 hp procurve 2848 Switches via snmp.
    Now i want to draw maps and include the switches in there.
    When drawing the connections, i need a trigger for the status of the conn.
    I thought i could set up the special trigger "status.last(0)", but that doesn't work:
    No such monitored parameter (status) for host (_1erswitch)
    Then i tried to ping the snmp port from my server.
    Therefore i created an item "net.tcp.port[1erswitch.bfk,161]" and a trigger for it. That Trigger is always "0".
    How can i get the status of the switch?
    Thx,
    Heiner
    Big ZABBIX is watching you!
    (... and my 48 hosts, 4513 items, 1280 triggers via zabbix v1.6 on CentOS 5.0)
  • Tenzer
    • Nov 2007
    • 316
    I check some HP procurve switches linkstatus by SNMP, it can be done through the ifOperStatus variable. It has a OID of: 1.3.6.1.2.1.2.2.1.8.[port]
    Maybe that could help you out?
    • just2blue4u
      • Apr 2006
      • 347
      That is to check the status of one of the ports.
      I need the status of the complete switch.
      So it's more a zabbix question than snmp, i think.
      Of course i could use any variable for the "switch is up/down"-Trigger, but i'm wondering why neither the zabbix status key nor the net.tcp.port item works
