Agent crashed
  • danomanno
    • May 2008
    • 14
    Agent crashed
    I am running 1.4.4 and every once in a while, a zabbix agent may crash. The server see it as "Not Monitored" under conf > hosts and the last data the server gets from that agent is "frozen" under "latest data"
    The problem is that I never get an alert so I never know that the agent is down. Is there a way to fix this so I get alerts when this happens?
    Thanks!
  • ldil
    • Jun 2007
    • 23
    Hi there danomanno,
    You can use a Agent Ping to see if your agent is still working if not then trigger a action.
    Item : Zabbix Agent : agent.ping
    Greetz Leo
    • danomanno
      • May 2008
      • 14
      I did have this already in items and in triggers. It failed to see this and on more than one occasion.
      • ldil
        • Jun 2007
        • 23
        I have used this for over a year now and it works great.
        So you are doing something else wrong then.
        ITEM: Zabbix Agent Ping agent.ping 120 90 31 ZABBIX agent Active
        TRIGGER : NC Zabbix Agent not working {NC_ZBX:agent.ping.nodata(1800)}=1 Information Enabled
        ALERT: NC_Zabbix_Agent [SMS/Mail Action] Trigger description like "NC Zabbix Agent"
        Send message to User "X_NC_MAIL-24"
        Send message to User "X_NC_SMS-08-22"
        Maby this will help you.
        Greetz Leo
        • danomanno
          • May 2008
          • 14
          Thanks! That worked.
          I had my trigger setup wrong. I needed this: agent.ping.nodata(1800)}=1
          The nodata is what I was missing.
          Thanks again!
