Ping between agents
  • thesb
    • May 2008
    • 9
    Ping between agents
    In order to have an accurate network map, I'm trying to configure zabbix to initiate ping checks from agents and return the results in milliseconds on Windows 2003. Is this functionality built into Zabbix or will it require additional scripting to function. If scripting is required, would someone offer some advice on how to execute this?
  • thesb
    • May 2008
    • 9
    Below is the script/config I used to get this working. I'm not all that familiar with VB so this could undoubtedly be more elegant. Anyone know if it's possible to pass an argument through the zabbix server item to the agent's script? It would be great to not have an entry for each host in the config and item on the server.
    VB Script
    Option Explicit
    Dim strHost
    strHost = Wscript.Arguments(0)
    if Ping(strHost) = True then
    Wscript.Echo
    Else
    Wscript.Echo "00"
    end if
    Function Ping(strHost)
    Dim objPing, objRetStatus
    set objPing = GetObject("winmgmts:{impersonationLevel=impersonat e}").ExecQuery _
    ("select * from Win32_PingStatus where address = '" & strHost & "'")
    for each objRetStatus in objPing
    if IsNull(objRetStatus.StatusCode) or objRetStatus.StatusCode<>0 then
    Ping = False
    'WScript.Echo "Status code is " & objRetStatus.StatusCode
    else
    Ping = True
    Wscript.Echo objRetStatus.ResponseTime
    end if
    next
    End Function
    Agent Config
    UserParameter=PingNode,cscript //nologo pingtest.vbs google.com
