ZABBIX installation manual
  • Neo
    • Jun 2005
    • 59
    Is the zabbix installation manual correct
    http://www.zabbix.com/manual_install.php
    Could anyone who has installed Zabbix sucessfully, explain the steps needed to get it up and working.
    I think the manual is wrong. Could anyone confirm this?
  • Neo
    • Jun 2005
    • 59
    I installed the Zabbix server and then went to localhost/zabbix
    but I can't login with "Admin" and empty password or anything.
    Is there something else I should do?
    • Neo
      • Jun 2005
      • 59
      Are you referring to that
      cat data.sql | mysql -u root zabbix
      step?
      I did that.
      I just did a
      select * from users;
      on the zabbix database and saw that there were some values in the passwd filed so I did an update and cleared them out, but I still can't login.
      Hey and thanks for the help gyrate.
      • Neo
        • Jun 2005
        • 59
        I tried with both cases. Nothing worked.
        Any other ideas?
        • Neo
          • Jun 2005
          • 59
          Did that too, still not able to login.
          • jldash
            • Jun 2005
            Did you make a zabbix user in MySQL, and if so, make sure that the config.inc.php and the db.inc.php files reflect the user and password that you gave to zabbix for the database connection.
            I had trouble at this step that was due to SELinux on Fedora Core 3...
            Hope that might give you some ideas.
            J
            • Neo
              • Jun 2005
              • 59
              SOLVED: see link
              I managed to solve this from the info provided in the followinf link.
